4WD acts upWD.
Old May 12, 2008 | 04:21 PM
bombadee's Avatar
bombadee is an unknown quantity at this point
Default 4WD acts upWD.
Hi
the vehicle is
2001 Chevroletr Blazer 4.3 automatic with push button 4
Old May 12, 2008 | 04:26 PM
WolfPack's Avatar
Default RE: 4WD acts upWD.
We're going to need a bit more information than that..
Describe 'acts up'. When does it act up....what have you tried so far? Does it do it every time?
Old May 12, 2008 | 04:31 PM
bombadee's Avatar
well I do not know what happened to the post so I will try again.
2001 Blazer 4.3 automatic with push button 4WD
going from 2 HI to 4 HI is fine.
However going back to 2 HI from 4 HI takes anywhere from 5 to 10 minutes whether the car is moving or not.
Any ideas?
Carl
Old May 12, 2008 | 06:30 PM
yazan84's Avatar
yazan84 is an unknown quantity at this point
I've had a similar problem last winter, but mine took awhile transferring from 2hi to 4 hi.
Does it do that when you're in park?
Old May 13, 2008 | 06:27 AM
bombadee's Avatar
It does not matter what gear I am in or even if I am stopped in or out of gear my only problem is going from 4 HI back to 2 HI. I remember reading somewhere that there was an adjustment that might be connected with this problem but that was quite awhile ago. I have posted this to a GMC forum and have not received any replies as yet so it must be something that no one has run into very much.
Old May 13, 2008 | 06:54 AM
bombadee's Avatar
I have been surfing all morning and might just have found an answewr.
Go to this link and read the post. It provides some really good info
http://autorepair.about.com/library/a/1/bl378.htm
j_rrod74
Apr 4, 2011 06:38 PM
GMC_Jimmy_13
Jul 12, 2010 05:37 PM
Shaggy
Jun 13, 2010 08:35 AM
yazan84
May 16, 2008 10:03 PM
Sparky
Feb 28, 2007 11:11 PM
