4wd connector wires/pigtail replacement
Old Dec 11, 2013 | 09:16 PM
neksys's Avatar
neksys is on a distinguished road
Default 4wd connector wires/pigtail replacement
So I've been having intermittent issues with my 4wd in my 2002 Blazer (occasional Service 4WD light, difficulty getting it to engage, etc).
I have the 4 button 4wd. I thought I narrowed the problem down to the switch, but upon replacing it, same problem.
Now I realize that it isn't the switch, its actually the connector itself (there are two, one controls the transfer case and one is, I believe, the lights).
If I hold the bundle of wires "just so" I can get the 4wd to work flawlessly.
I would like to replace that section of wires and the connector - but I can't seem to find the part. I have found the other connector online through various sources but not the 8-pin connector I need.
Has anyone seen this part out there, or have a part number? I'm pulling my hair out!
Old Dec 11, 2013 | 09:47 PM
richphotos's Avatar
Why not just pull the connection apart, and fix them, there is a way to get the prongs out of the connector, and clean, make sure they are hooked up tight, and pinch them down a bit so they have a tighter connection on the switch.
Old Dec 12, 2013 | 11:41 AM
neksys's Avatar
Never thought about that for some reason. Thanks I'll give that a shot, see if its possible.
Old Dec 12, 2013 | 12:20 PM
spittybays
Guest
Posts: n/a
Old Dec 13, 2013 | 11:14 AM
neksys's Avatar
Originally Posted by spittybays
Thanks! It looks just like PT266, except mine has 8 wires instead of 6.
Old Dec 13, 2013 | 03:50 PM
swells87's Avatar
swells87 is on a distinguished road
why not go to a junk yard and see if you can find some plugs in good shape, than cut and reconnect them into yours.
maxvamp
Oct 31, 2020 08:19 AM
fasteddie333
Dec 16, 2011 09:29 PM
kingjames1
Nov 28, 2011 04:53 AM
Salvatier
Oct 4, 2011 09:21 PM
rogggg1020
Sep 24, 2008 06:53 AM
