4WD question?
Old Dec 28, 2014 | 03:49 PM
Possum 6991's Avatar
Possum 6991 is on a distinguished road
Default 4WD question?
I have a 2000 Blazer with a 233 transfer case (3 button switch). My question is how hard (or easy) should it be to move the fork that the actuator cable pulls on.
Old Dec 28, 2014 | 04:09 PM
The shaft for the fork only moves about 1/4", is this what the total movement should be?
Old Dec 28, 2014 | 04:20 PM
newguy's Avatar
Yes it is
Old Dec 28, 2014 | 04:24 PM
Blazin00LT's Avatar
Blazin00LT is on a distinguished road
The shift fork should move real easy provided the diff and axle are lined up.
Old Dec 28, 2014 | 06:23 PM
My actuator has vacuum to it but it does not seem to pull hard enough on the shift fork to drive the axle. If I pull on it manually it does engage the axle. It does not seem like I pull too hard but the actuator does not pull it far enough. The cable and actuator are new. I have already replaced all of the vacuum lines (they were in real bad condition). I have about 20" of vacuum (250K miles).
Old Dec 30, 2014 | 10:32 PM
So how does someone check the alignment of the front axle to differential? I suppose that there is some kind of adjustment? I was thinking that the fork may be just gummed up? I know that when I did pull the fork that it does lock/engage the axle to the front drive shaft. I did notice that when I let go of the fork that it did not go back in until I rotated the wheel in an opposite rotation a little bit. I’m thinking that I will probably have to remove the half shaft to check for gumming/broken parts. Sounds like a pain in the…
Old Jan 1, 2015 | 04:42 AM
There is no alignment of the front axle to differential, it just bolts together. Everything with engagement and disengagement that you described is normal. Could very well be low vacuum to the actuator. Pull the vacuum line off the actuator, and install a vacuum Tee in the line. Install a vacuum gauge to one leg of the tee. Connect the actuator to the remaining leg of the tee. Start the engine and select 4WD. Make a note of the vacuum reading. Shut the engine off. Does the vacuum on the gauge hold, or drop off?
Old Jan 1, 2015 | 10:59 AM
Blazin00LT's Avatar
My guess is there is a hole in the accumulator, they aren't getting any younger and like to dry rot with time.
Old Jan 1, 2015 | 09:00 PM
I checked vacuum at the actuator. Found no measurable reading on the gauge but the actuator does pull a little bit. Previously replaced the actuator, all vacuum lines and the vacuum switch at the t-case due to transmission fluid in them (seal from transmission to t-case has been replaced). I checked vacuum at the vacuum switch plug and had about 17". So either the new line from the vacuum actuator to the vacuum switch on the t-case is kinked or has a whole in it or possibly the new vacuum switch is bad (is this correct thinking)?
Old Jan 1, 2015 | 09:05 PM
Could be, but it could also be that the lines are not in the correct position on the vacuum switch.
