4x4 actuator is stuck in 4 hi
Old 07-26-2012, 10:49 AM
Aanenson's Avatar
Aanenson is on a distinguished road
Default 4x4 actuator is stuck in 4 hi
My 4 wheel drive is stuck in 4 hi, ive been thinking of getting an aftermarket actuator, and all ive found is dorman, i just wanted to see what you all had to say about that or any other aftermarket actuators? I just dont want to spend 350+ bucks on an OEM actuator, the dorman 600-900 actuator i found is around 117 bucks right now it looks like ill be going towards dorman, but like i said if you all know any others or better manufacturers please let me know!!!
Old 07-26-2012, 01:52 PM
aa21830's Avatar
aa21830 is on a distinguished road
There's a lot of reasons it could be stuck in 4WD. Have you gone through all the diagnostics? That's a lot of money to spend on hope....
Old 07-27-2012, 08:52 AM
neo71665's Avatar
The actuator is only a rubber bladder that uses vacuum to pul a cable to lock the pass side axle in for 4wd. When they fail the axle doesn't lock in.
I bet you have either a frozen cable from the actuator to the axle or a bad vacuum switch on the t-case.
Pull the vacuum line off the actuator, plug it so you don't have a leak, and see if that unlocks the front axle. If it doesn't with the line unhooked grab the actuator squeezing it and see if the cable moves back and forth.
Old 08-07-2012, 06:44 PM
Aanenson's Avatar
hmmm ok, my dad had a new transfer case put in it too a couple of months ago, right now its out of 4 hi, my girlfriend pushed the 2 hi button and it went right in no problem so im not even messing with the 4wd right now lol, the service 4wd light comes on when i hit a big bump example railroad tracks at highway speeds, and when i go through water/mud or just going down a gravel road, what would be the most likely cause? thanks all for the help!!!
Old 08-07-2012, 07:49 PM
mychevyisntheavy's Avatar
mychevyisntheavy is on a distinguished road
id check all the connections ie wiring, and if is bolted up rite.
mr.vls
05-04-2013 03:45 AM
closer
11-11-2012 05:46 PM
Havensk
07-25-2010 08:16 PM
markrd
05-08-2009 01:39 PM
ejp
01-04-2009 02:47 PM
Quick Reply: 4x4 actuator is stuck in 4 hi
