4x4 issue
Old Jun 17, 2010 | 02:45 AM
apross44's Avatar
apross44 is on a distinguished road
Default 4x4 issue
I tried posting this under another thread but no one had responded so I made a new one. I have a 98 blazer 4wd with the 3 button switch on it and I can't shift into 4hi at all. My lights will blink on the switch then sometimes either go out all together or will keep the 4hi and 4lo lights on. and when I shift it into 4lo the truck feels how a car feels when the clutch is slipping and barely move (it is an automatic). is this just a problem with the vacuum line and I need to change it or what? any help would be great.
Old Jun 17, 2010 | 04:04 AM
TreasonAgainstCaesar's Avatar
TreasonAgainstCaesar is on a distinguished road
Is your service engine light on? If so, get the codes pulled. If not, I think the dealership can pull the error code from the 4wd encoder.
Old Jun 17, 2010 | 04:27 PM
apross44's Avatar
my check engine light is not on at all the only time it came on was when my coolant was low when I changed my radiator.
Old Jun 21, 2010 | 07:49 PM
Now that I've thought about it some more, I think the sequence of blinks is actually a code that indicates what the problem is. You might need to go to the dealer to find out what the code means. Or try watching the sequence and search for some information on it?
Old Jun 21, 2010 | 09:04 PM
89s10blazin's Avatar
89s10blazin is on a distinguished road
hey man, i'd say check the fluid first! the most common problem is low fluid. some of the t cases need special GM fluid so look into that( if so it will say rite on the case)
Old Jun 22, 2010 | 09:35 PM
apross44's Avatar
I heard that somewhere but I wasn't sure if it was true. I will definitely look into that.
Old Jun 22, 2010 | 10:26 PM
Hanr3's Avatar
theree used to be, and proble still is a DIY thread on the electronic 4x4 system. Someone went into great detail about trouble shooting the problem.
I dont think it a vacuum line issue.
brian79z
32
Feb 23, 2015 07:13 PM
99bblazer99
Jun 15, 2013 08:38 PM
J.R. Clay
Mar 16, 2011 12:33 AM
camino88
Jan 7, 2010 12:51 PM
extreme
Jan 5, 2010 07:29 AM
