4x4 Problems
Old Jan 12, 2010 | 11:34 PM
nlohman0717's Avatar
nlohman0717 is on a distinguished road
Default 4x4 Problems
I have a 1995 Blazer 4wd 4.3 v6....My 4wd seems to be malfunctioning...I'm not really sure where to start because its a pretty complicated problem...First of all I know its not the actuator under the battery...I checked it and it's fine...second, I know its not the vac switch on top of the transfer case...I replaced that already...so here's whats going on...First, sometimes when I start the car the light for 2wd does not turn on for a few minutes...I found that weird, second, when the 4lo button is pressed the car will go into 4lo, but it doesn't seem to want to go into 4hi..also sometimes both the 4lo and 4hi lights are lit on the switch, and some other times i get the "blink blink blink" then nothing...as I said it goes from 2wd to 4lo no problem but 4hi isn't working....any suggestions...thanks
notrealimportant
Jul 15, 2011 01:29 PM
Aanenson
Apr 14, 2011 09:12 PM
upblazer95
Apr 4, 2009 08:27 PM
chevblazer02
Oct 15, 2006 03:03 PM
vtlew
Jun 23, 2006 09:13 PM
