4x4 or standard 4L60E
Old Mar 19, 2018 | 05:12 AM
Duane Ward's Avatar
Duane Ward is on a distinguished road
Default 4x4 or standard 4L60E
First timer here, thank you in advance for your time and ideas/thoughts!! I have a 2001 4x4 ls four door with no reverse and it seems as though the trans is causing the engine to hesitate in forward gears. My question is can I use a standard 4L60E trans and if so are there any mods needed to fit a standard into a 4x4 chassis?
Old Mar 19, 2018 | 07:12 AM
LesMyer's Avatar
4x4 transmissions are specific to 4x4 as the output shaft is designed to go into the transfer case (much shorter). You can change the output shaft, but that requires major trans disassembly. Others can answer about the applicability of different year 4L60E's to your vehicle.
Old Mar 19, 2018 | 09:53 AM
rockp2's Avatar
When you say "standard" are you referring to a manual shift? A 4L60E is an automatic trans. Standard transmissions for these trucks are (for example) NV1500, NV3500.
Old Mar 19, 2018 | 12:57 PM
Duane Ward's Avatar
I meant standard as in standard automatic transmission. I just want to know if I can put a non four wheel drive automatic in my truck. It will allow me to more readily acquire a new trans. I dont ever use the four wheel drive any way. Thanks guys!
Old Mar 20, 2018 | 06:21 AM
Transman304's Avatar
Transmission must be a 4x4 set up. Output shafts are longer on 2wd and will not work.
MUDTRUCKMAN
Mar 15, 2017 09:45 PM
dj00140
22
Nov 4, 2015 05:03 AM
an240172
Sep 7, 2009 02:58 AM
supercoop
Tires and Wheels
Oct 13, 2008 10:38 PM
95blazer8620
Oct 19, 2007 01:26 PM
