4x4/tccm malfunction after battery disconnect
Old Jan 4, 2023 | 04:01 AM
sliptheknot77's Avatar
sliptheknot77 is on a distinguished road
Default 4x4/tccm malfunction after battery disconnect
Hello all,
I recently took my 2000 blazer 4WD for a serpentine belt replacement. The battery was disconnected and after being reconnected the kick panel box ticks and the 4w panel lights up on and off. Initially the car had acceleration issues that were later resolved (for now) after promptly driving it back to the shop. The battery was disconnected and the terminals were cleaned. The issue with the 4w has persisted. Now I’m looking at a $200 diagnostic fee and the cost of possibly replacing the tccm. Never had this issue before and only appeared after the battery removal. Any help to resolve would be greatly appreciated!
thank you,
dave
Old Jan 4, 2023 | 12:00 PM
Because it is easy to check, I'd take the kick panel off and visually inspect the TCCM and its electrical connections in the plug and socket. Some have reported that the terminals can get corroded.
The failure of the TCCM being due to the battery disconnect could be true or just a coincidence.
The clicking TCCM is something many of us have had to face.
if you are near a wrecking yard, you might try getting a used one. If you have a U-Pull yard, then since it is so easy to remove one on your own, you can save even more money. I think the U-Pull yard I've used might charge $30 for general electrical parts. You can always call ahead and ask the price too. My advice if you get one from any wrecking yard would be to make sure you get a TCCM with a compatible part number and transfer case. The transfer case will either be a "3-button" or "4-button" type. The 4-button has a fourth "Auto 4wd" button.
You can check the part numbers for different years by looking at a GM parts website. I like using this one: https://www.gmpartsgiant.com/. There you can put in your Blazer info or the VIN to find compatible parts. You then can look at other year Blazers to see if they use the same part numbered TCCM. You might have to have your list of RPO codes from the sticker on the inner panel of the glove box door to check the RPO code for the transfer case you have.
Good Luck.
Old Jan 4, 2023 | 12:21 PM
LesMyer's Avatar
Originally Posted by sliptheknot77
Hello all,
thank you,
dave
Why was the battery cables or battery removed for a serpentine belt replacement? I feel like we're not getting the entire story. Christine gave you good advice about checking the terminals on the TCCM for corrosion - specifically the two big heavy wires.
Old Jan 4, 2023 | 03:25 PM
Good Luck.
thank you!
Old Jan 4, 2023 | 03:27 PM
I was not given a reason why the battery was disconnected unfortunately
Old Jan 5, 2023 | 01:20 AM
Good Luck.
negative battery terminal was a 1/4-1/2 turn loose. Tightened er up an volla! Glad I didn’t tear apart my kick box, but thank you again for the info!!!!
Old Jan 5, 2023 | 01:24 AM
Yeah! Gotta love those easy fixes!
Thanks for the update.
William Kimmel
Jan 6, 2011 06:18 PM
tjmicsak
Nov 28, 2010 08:19 PM
derby66
Feb 1, 2010 12:52 PM
Gearhedd
Jan 5, 2010 07:25 PM
vrryder
14
Nov 2, 2009 03:37 PM
