4x4 won't go to 4hi
when i press 4hi, 4hi button lights up as if there were no problems, but it engages in 4lo instead.i can go back to 2hi from there but i have no 4hi. so i'm assuming the vacuum to engage 4x4 works and whatever switches it from 4lo to 4hi is the culprit.
Do you have Auto4wd? If not, check out the thread in the DIY section. OBD2 Non-Automatic Transfer Case Diagnostics
jeffrozar
Nov 4, 2011 03:49 PM
jeffrozar
Nov 4, 2011 10:08 AM
