#5 cyl full of gas
#5 cyl full of gas
Im back with another problem. 95 blazer stalled and wouldent start. Checked battery and starter both ok seemed like motor was locked up. Pulled plugs and about a cup of gas came out of #5 cyl. Motor cranks fine now but keep getting gas from #5. No gas in oil. CMFI shot??? any help will be appreciated
A leaking injector would fill all of the cylinders on the CPI engine given the configuration of the spider. This is likely caused by a failed fuel pressure regulator. To replace it, you have to pull the spider which means disturbing the "nut kit" (internal fuel lines) which must be replaced unless you want to be back in there again in short order.
There is a how-to in the tech article section on this repair.
goerzenl
11-01-2010 10:14 PM
vaportrail
38
09-21-2009 05:38 PM
midnightbluS10
09-03-2009 03:24 PM
