5 Speed Manual Trans problem
Old Apr 19, 2008 | 09:08 AM
mow10man's Avatar
mow10man is an unknown quantity at this point
Default 5 Speed Manual Trans problem
I have a 99 2wd s-10 blazer, first gear kicks out when you try to start from a dead stop. I have to start in 2nd gear. Any thoughts? I only have 48k miles on it.
Old Apr 19, 2008 | 10:19 AM
houdini_dan's Avatar
houdini_dan is an unknown quantity at this point
Default RE: 5 Speed Manual Trans problem
can you hold it in gear when it kicks out? I have a neon the does that in fifth gear. i'm pretty sure its the syncro for that gear. sounds like you may have the same problem.also check to see if there is anything obstructing the shifter or linkage.
Old Apr 19, 2008 | 11:14 AM
blazin97's Avatar
blazin97 is on a distinguished road
yah sounds like a syncro to me(my s10 used to do it in 5th). Do you tear it up in 1st? It usually doesnt happen to the lower gears.
Old Apr 19, 2008 | 11:20 AM
drperry's Avatar
My '85 S10 was doing that to me when I traded it in...
I also beat the ever loving snot out of it, so that's probably why it was happening
Careful trying to hold it in... Mine could bruise a hand when it popped out! lol.
Pretty sure it's the synchros...
Pipewrench Dale
Nov 10, 2014 06:16 PM
siccnezz
Mar 20, 2011 09:33 AM
xtreme821
Oct 24, 2010 09:32 AM
ducky
Feb 14, 2009 03:30 PM
