manual trans problem i need help
Old Feb 14, 2009 | 02:09 AM
ducky's Avatar
ducky is an unknown quantity at this point
Default manual trans problem i need help
i have a 85 s10 blazer 4x4. the clutch went out and the shifter is in neutral but the trans is still in a gear. does anyone know how to get it out of gear so i can pull the driveshaft and drop the tranny
Old Feb 14, 2009 | 01:17 PM
Default RE: manual trans problem i need help
I do not think you need to have it in neutral to do the work required... Well, that is unless you cannot jack up the truck and remove the driveshaft where it sits now. Does the shift lever move at all?
Old Feb 14, 2009 | 03:30 PM
ducky's Avatar
the shifter moves it just wont go out of gear and ive tried to take the drive shaft out and its suck. also the blazer is not in a place where i can jack it up its in a feild just behind my house and the shifter does move it just wont go out of gear
flipzat
Nov 30, 2009 11:28 PM
BlazeringSaddles
34
Nov 29, 2009 01:35 AM
mow10man
Apr 19, 2008 11:20 AM
rooster
Nov 10, 2006 08:55 PM
Blaze1996
Engine & Internal
Dec 11, 2005 05:39 PM
