7004r to a stick shift
Old Jun 7, 2011 | 12:47 PM
Chenzo's Avatar
Chenzo is on a distinguished road
Default 7004r to a stick shift
ive got a 1992 s10 blazer 4x4 4.3l with the 7004r trans. i tried putting a shift kit in it but it didnt come out well and now i must make the decision to either
1) completely rebuild the trans back to stock
2) buy a new trans
3)replace the trans
i recently have fallen in love with stick shifts and hate not having control of my blazer. ive looked around and cant seem to find any info on a manual 1992 s10 4x4 4.3 blazer or truck, does it exist? if so then this would be an ideal donor. if not is it realistic to put a standard in or should i just rebuild get it back to stock and get a different car thats a standard. ive built the truck from stock and love it, but lately whenever i drive it i get angry as i loose almost all torque after 45mph and 2300rpm so any idea opinions or a general response will be of help
Old Jun 7, 2011 | 08:49 PM
Blazer Steve's Avatar
Blazer Steve is on a distinguished road
Default 700r4
Hello
Sorry about your 700R4, did you use one of those piece of crap shift kits from B&M if so you will have nothing but problems.
I have a 1997 s-10 blazer rebuilt engine and trans went to this site and used one of his Heavy Duty package works great I have full manual control or full automatic control.
700R4 & 4L60E Automatic transmissions specialists - ProBuilt
Old Jun 7, 2011 | 09:35 PM
Chenzo's Avatar
It was a transgo kit. Directions were terrible and most of it was guesswork =\
You have both full manual and full auto? How does that work?
Old Jun 7, 2011 | 11:41 PM
Oystein's Avatar
Oystein is on a distinguished road
I have a stick shift in mine (from factory). Works well.
Old Jun 8, 2011 | 04:19 PM
Chenzo's Avatar
What year did it switch to second gen? Would one from the '94 bolt up nice And work With the electronics?
Old Jun 8, 2011 | 09:01 PM
warthogdriver's Avatar
if you do a manual swap you will need a donor vehicle...you will need the tranny as well as electronics to transfer over.
Old Jun 8, 2011 | 09:07 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
Switched to 2nd gen in '95
Old Jun 8, 2011 | 11:46 PM
Chenzo's Avatar
So basically just keep an eye out for a first Gen with. Standard and it should work good with mine?
Old Jun 9, 2011 | 10:36 AM
Oystein's Avatar
I don't see why not
Old Jun 9, 2011 | 04:29 PM
Chenzo's Avatar
alright well i would rather spend the money on the switch over than an automatic so ill start looking around for the donor. i can get everything from the donor but should probably get a new clutch pressure plate and throwout bearing correct?
Kilo
Feb 5, 2013 02:05 PM
weightofast
Jul 16, 2012 03:42 PM
DANI915
Mar 22, 2011 09:28 PM
FImports
Tires and Wheels
Dec 11, 2006 10:42 PM
zero psi
Sep 27, 2004 01:20 AM
