700r4 to 71blazer manual tran swap
Old Apr 9, 2016 | 11:33 PM
Bonnie15's Avatar
Bonnie15 is on a distinguished road
Cool 700r4 to 71blazer manual tran swap
found easier/cheaper way to put a700r4 in my 71K5 blazer with out changing or moving transfer case. U put a output shaft in the 700r4 and a adapter to my np205 this is apx. 4inch longer. move motor forward re-drill holes in frame on motor mounts cross member , add 4 inch's to exhaust pipe ,an throttle linkage . they make a kit with output shaft an adapter. I don't have to change transfer case, drive shafts, or shifting controls I have 12inches from water pump to radiator so lots of room there. There will be a few other things to do like rad. hoses PS hose little stuff
Old Mar 22, 2021 | 08:08 PM
mark71j's Avatar
mark71j is on a distinguished road
How'd that turn out?
inthepaint
Feb 24, 2020 03:14 PM
jesi
Sep 25, 2012 06:36 PM
Razorburn71
18
May 15, 2011 04:52 PM
RCG
May 7, 2009 10:15 PM
amp88fan
Sep 27, 2008 03:09 AM
