750 4 barrel edelbrock on 305??
Old Apr 25, 2010 | 12:00 PM
K5countryboy's Avatar
K5countryboy is on a distinguished road
Default 750 4 barrel edelbrock on 305??
i just bought a 86 with a 305 and it has a 750 4 barrel edelbrock. Im thinking its to big for that motor. When coming off the line if just wants to bog down and runs very very rich. i dont know if it needs to be carb needs to be adjusted but i really think its to big. What do yall think???
Old Apr 25, 2010 | 12:24 PM
84BlazerS10's Avatar
I don't know much at all about carbs but I would assume you just need to adjust it.
Old Apr 25, 2010 | 12:57 PM
rriddle3's Avatar
Unless the engine has been heavily modified, that carb is way too big for it. You should have one in the 600cfm range. for 'carburetor size' and you can find plenty of info.
Old Apr 25, 2010 | 03:47 PM
If the carb has vacuum secondaries, then it can live on top of that motor if it is adjusted properly. It will be much easier to adjust a smaller carb though.
Old Apr 25, 2010 | 06:45 PM
Thanks bud. will take a look.
thats the thing, i dont know if anything has been done to the engine. If i had to take a wild guess im sure something has been done to it. Who ever owned it before me made it for a toy. But yes i agree i think its too big.
Last edited by swartlkk; Apr 25, 2010 at 06:51 PM. Reason: **Combining Consective Posts** - Please use the EDIT feature to add information to your post if another member has yet to reply.
Old Apr 25, 2010 | 09:08 PM
AJBert's Avatar
Are you 100% sure it is a 305 and not a 350? I know that 305's came stock in those years but the engine may have been swapped out since. Hard to tell just by looking at them, you'll need to run the cast numbers to be sure.
A simple fix for it running to rich is to put in smaller jets rather than replacing the entire carb.
Old Apr 25, 2010 | 09:56 PM
No im not a 100% sure its a 305. The labels on the hood say its a 305. Where can i find the cast number located on the engine? i mean for that matter the truck has almost 200,000 miles on it and runs like a champ, well except for the tranny
Old Apr 26, 2010 | 03:58 AM
neo71665's Avatar
Casting numbers are on the block behind the drivers side head. Major PITA to see most of the time.
Old Apr 26, 2010 | 06:13 AM
You'll need the numbers off the back of the block behind the driver side head as well as suffix codes off the top of the deck right in front of the passenger side head and behind/under the alternator to fully identify the block. Hopefully the deck hasn't been cut.
Also, the head casting codes can be beneficial if the motor came complete from something else. Those are under the valve cover.
PogiMoto
Tires and Wheels
Jan 29, 2019 05:43 AM
WHTTA
Feb 24, 2013 08:30 PM
JustJerry
Engine & Internal
16
Apr 25, 2011 05:34 PM
blazer073
Aug 21, 2010 02:37 PM
quarterhorseluver
May 7, 2010 08:06 PM
