78 Blazer High RPM Problem
Old Oct 6, 2013 | 03:33 AM
XFX's Avatar
XFX
XFX is on a distinguished road
Default 78 Blazer High RPM Problem
hi
1978 Chevrolet Blazer , Manual , carburetor V8 350 Ci
when i starts the engine the RPM jump over 3000 and stay there , no matter i put shifter in gear or it's on idle the RPM stay above 3000 !
i have checked the Vacuum and carburetor and also Wire gauze !
now i don't know what to do !!!
any Idea ?
Old Oct 6, 2013 | 09:46 AM
abig84's Avatar
there is a adjustment screw on the carb for the idle. it may just need to be loosened. also make sure its returning all the way back to idle position. sometimes a vacuum line or other crap will get lodged behind it
Old Oct 15, 2013 | 10:01 AM
chevman24's Avatar
chevman24 is on a distinguished road
That is a high idle. Check for a Vacuum leak somewhere. Intake gasket area, carb gasket are where I would start. The carb baseplate could be worn too causing the throttle blades not to fully close.
bear159
Dec 7, 2023 09:11 AM
mcdevin1973
Oct 5, 2014 02:52 PM
242176
Oct 30, 2011 10:12 PM
blazerboy30
Dec 1, 2007 11:16 PM
newowner
Sep 27, 2007 08:17 PM
