88 k5 stalling
Old Feb 17, 2008 | 10:52 PM
jdietschweiler's Avatar
jdietschweiler is an unknown quantity at this point
Default 88 k5 stalling
NEED HELP 88 k5 blazer 350 tbi stalling in gear while coasting and light acceleration. worse when cold but sometimes at engine temp
Ran injector cleaner in gas also cleaned throttle body No vacume leaks as far as I can tell. Runs fine in park put it in drive some times stalls. Driving down the road let off the gas it stalls but not every time PLEASE HELP thanx John
Old Feb 18, 2008 | 01:25 AM
Chevy Lover's Avatar
Default RE: 88 k5 stalling
What RPM does it idle at in "P" and what RPM in "D"? Will it stall sitting at a stop in "D"?
Old Feb 18, 2008 | 03:22 PM
no tach in truck in drive with breaks applied wont stall
Old Feb 19, 2008 | 10:08 AM
I would suggest hooking up a scanner and monitering the IAC. Check for any codes as well.
Old Feb 19, 2008 | 02:14 PM
Replaced the iac and throttle pos sensor no dice
kkramer7
May 9, 2006 07:44 PM
sinkerman
Mar 16, 2006 10:07 PM
mike97blazer2DR
Jul 22, 2005 01:04 AM
bravadaguy
Jul 1, 2005 02:42 PM
m00nwater
Apr 16, 2005 12:06 AM
