'89 Blazer - No Start, weak spark
Old Sep 28, 2010 | 07:41 PM
'01zr500's Avatar
'01zr500 is on a distinguished road
Default '89 Blazer - No Start, weak spark
I have an 89 blazer 350 that will not start. I use it as a plow truck to plow my 1000' driveway clear of lake effect snow. (She pushes way better than any Ford.)
What I have verifed.
Cap and Rotor are good. Plugs are good. (New Last Year)
Grounds are clean (pain in the A$$ and time consuming)
I am getting fuel at the carb.
She will not start with start fluid.
Spark is weak. (Yellow)
I have changed in order listed:
New Gas
Igniton coil
Ignition Control Module (New)
What am I missing?
Snow is coming and I am getting anxious. (I live south of Buffalo, NY)
Old Sep 28, 2010 | 07:50 PM
abig84's Avatar
kinda a long shot but look up your tailpipe, if the truck has been sitting all year maybe something crawled up there and died blocking the exhaust.
after cranking it a while pull a out a plug to see if its wet then you know fuel is getting into the truck.
try cranking with the cap off, possible broke timing chain?
old trucks are pretty simple. if its got spark and gas itll run
unpredictable1
24
Jan 10, 2016 10:22 AM
naveedmerchant
Nov 14, 2013 09:12 AM
Crestwood1001
Jun 2, 2009 09:02 PM
patterrr
Oct 24, 2006 03:50 PM
blazinloud
Engine & Internal
Oct 17, 2006 05:39 PM
