89 K5 4lo will not engage
Truck has a turbo 350 and I guess a stall convertor. Not that it matters for my question. We cant get it to engage into 4 wheel low. The shifter moves between 2hi and 4 hi like normal. But will not go into 4 low at all. Where do I start? Thx
Have you tried engaging 4LO with the transmission in neutral and the truck just slightly rolling? Sometimes it can be a bit difficult to engage 4LO if the gears inside the transfer case are not perfectly aligned. Rolling can help them mesh up.
For 4lo you must have the trans in neutral but it can depend on the transfer case. If you have a 205 that is gear driven it must be in neutral not moving. If its a 208 you still must be in neutral but can be rolling slowly.
Monkeyman
Jan 9, 2014 03:59 PM
sedatedbylife
15
Jan 23, 2012 09:26 PM
matt94
Nov 21, 2011 09:22 PM
