89 s-10 Blazer occasionally won't shift gears
This just started, when driving...everything is fine then go to shift gears and it will come out of whichever its in but then trying to put it in any other gear doesn't happen.
Pull over and turn off the engine, on restart (which seems to hesitate) I can get it into gear and it seems ok. Happened twice now.
Any ideas?
Any ideas?
Sounds like the linkage may need adjusted or a possible worn fork. When you shift gears make a concious effort make absolutely sure its solidly shifted into the next gear. This may be hit or miss but If that helps its probably the linkage or shift fork.
Other possibles are a worn bearing or syncro.
CleverName
10-28-2014 11:54 PM
cavired99
05-12-2014 10:27 PM
Indy2011
01-25-2011 02:04 PM
pigmak
06-25-2009 06:12 PM
