89 s10 blazer dies then starts moments later
Old Feb 26, 2013 | 04:10 PM
  #21
mr.vls's Avatar
On the 89 there is no test port. I purchased a fuel pressure test kit that i hook up in line at the frame rail where the fuel lines to the TBI connect to the fittings via hose clamp. I have since installed an inlline fuel pressure gage at the inlet port for the TBI. I purchased the inlet fitting and gage from CFM technologies. Just for info the TBI needs to have around 11 psi. I think the spec is 9-13 PSI
Old Feb 26, 2013 | 04:14 PM
  #22
kylehutch3's Avatar
kylehutch3 is on a distinguished road
that would explain why i couldnt find it. thank you. looks like im dropping the tank and switchin the fuel pump.
Old Feb 26, 2013 | 04:20 PM
  #23
Thanks! I had an 89 too! You'll have to put a Tee in the line, here is a cheapie that works fairly well and comes with the tee: Fuel Pressure Tester & Fuel Injection Pump Tester
Old Feb 26, 2013 | 04:32 PM
  #24
kylehutch3's Avatar
thank you. im currently jobless and dont have much tools/resources to use but it helped alot
risbel2009
Jun 20, 2011 06:36 PM
reddheadnla
Apr 23, 2011 11:08 AM
sk8_dude90
Nov 30, 2010 02:25 AM
Blazer Will
Dec 13, 2009 06:22 PM
TTATE
Aug 11, 2009 07:43 PM
