91 Jimmy timing question
Old Oct 28, 2013 | 11:19 PM
yuka42's Avatar
yuka42 is on a distinguished road
Default 91 Jimmy timing question
Hey all! Got a quick question about engine timing....
1991 GMC Jimmy 4x4 4.3L "Z" engine TBI
Here's the back story. I recently put new intake gaskets (were leaking coolant) and new valve stem seals (was blowing blue smoke) and a new water pump, new lower rad hose, new serpentine belt, and rebuilt the throttle body (new gaskets, o rings, fuel regulator, etc)
I got her all back together and running! Ya me! Never done anything remotely like this before. I watched alot of youtube vids and read forums and the chilton book back to back a few times. I had some knowledgeable help too. Anyway....
I set the timing to 0 degrees...and the engine was running but didn't seem quite right. Came back inside, did some research and learned about the unplugging the EST wire thing. Unplugged it and checked timing. Was at least 12-15 ATDC and running fairly rough (sounded nice tho, throaty...haha). Brought it up to zero degrees again and it was running better. Shut it off and plugged the EST wire back in. The timing is now up to around 10-12 BTDC. Seems to be running well. Drove it around all day. No stalling or miss fires or knocks....but it still doesn't seem quite right. Maybe a little sluggish, not as smooth as I think it could be. Does that number seem right? Or should it remain at 0 degrees after that wire is plugged in.
On a side note, when replacing the valves, we removed lash, and only did a half turn on the nut. I've seen everywhere from a quarter turn to One full turn in the chilton book, to 1 3/4 turns. Could this be an issue? You can hear maybe a wee bit of chatter through the wheel well, but not much. Most of the "chatter" sound seems to come from the TBI fuel injectors.
Thoughts??? Thanks in advance.
Old Oct 29, 2013 | 01:24 PM
abig84's Avatar
yeah you did it right, time it to 0 with it unplugged and the computer advances it. could be any number of issues, distributor advance might be bad or other issues
Old Oct 29, 2013 | 03:25 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Doctorvette
Nov 5, 2012 11:57 PM
Denominator
Sep 23, 2010 02:40 PM
hotrodln
17
Apr 26, 2010 07:32 PM
Denominator
Apr 25, 2010 06:31 PM
apekim
Jul 19, 2006 12:09 PM
