91 k5 400R4 Trasmission swap
Old Nov 25, 2022 | 12:02 PM
91k5newbie's Avatar
91k5newbie is on a distinguished road
Default 91 k5 400R4 Trasmission swap
So I apologize if there is a thread for this already and I just missed it. Having issues with my 700r4 making cyclical grind noise in reverse, will drive in 1st gear but second is gone. So I found another 700r4 from a donor vehicle. Both have the old TV style cable. The TBI was removed and an aftermarket carb setup was run on both trucks.. So my question is since they were both running and driving fine before, will the donor trans be able to be bolted in or will adjustments need to be made? I had one shop tell me they won't do the swap as I will just burn it up because of the switchover to a carburetor. Thanks for any input. It is much appreciated.
Old Nov 26, 2022 | 09:56 AM
The TV cable MUST be adjusted properly if you want the transmission to last. I wouldn't take for granted that it will be right just because they both had carburetors. It's not that difficult to check/adjust, but I'm not really familiar with the procedure. I'm sure you can find it with a quick search, though.
Dmoore78
13
Jan 13, 2019 10:17 PM
Jasongr81
Jul 19, 2013 02:13 PM
r_marczak_83
14
Feb 2, 2013 10:28 AM
smg614
Sep 16, 2012 02:04 PM
Keith Epicwin Warren
Feb 16, 2012 02:56 PM
