91 s-10 blazer 4x4
91 s-10 blazer 4x4
hey ya'll i'm thinkin about either doin a 350 swap or just buildin th stock 4.3 up what are the pros and cons of each?
Don't hold me to this but just some thoughts: SB build fairly cheap and an almost unlimited availability of parts and options. However I am not to sure what and if any mods will need to be done to the frame suspension etc. 4.3 build is a direct fit but limited performance parts.I love the small block idea but you will need to do your homework before you start. Good luck with which ever you decide.
By the way:
Welcome from New York!
By the way:
thanks guys, but the 4.3 is just a v-8 with two pistons cut off so the whole bottome end is the same not sure if that makes a difference or not but just thought i would show ya what i know
tdbone1
15
11-30-2012 06:53 PM
Tinted
35
02-07-2011 01:12 PM
BaLListic_Evo
06-04-2010 03:38 PM
razman
02-22-2009 01:57 PM
