91 s-10 blazer only starting when given gas
Old Feb 5, 2022 | 11:14 AM
billnyethebasic's Avatar
billnyethebasic is on a distinguished road
Default 91 s-10 blazer only starting when given gas
So I have a 91 s-10 blazer it’s got plenty of issues but it’s my first car and kinda just learning about it as I go but a while ago it started not wanting to run unless I gave it gas and would die when I’d take it out unless I was giving it gas sometimes it’s idle for a bit but not for long the only time it’ll idle is when I first start it after giving it some gas or turning the ignition back and fourth a couple times but it stills idles rough I’m not sure if it could be fuel presser or fuel pump or another issues just wondering if anyone else has had a similar issues and if they’re are more ways to diagnose the issue
Old Feb 5, 2022 | 02:26 PM
GeorgeLG's Avatar
This can be many things. Let’s start simple:
make sure you have a new air cleaner and no restrictions
new fuel filter
clean the throttle body
Clean the EGR valve if equipped
clean the IAC valve
if that doesn’t do it then we move on to testing:
iac valve
tps
fuel pump
map sensor
oxygen sensor
fuel injectors
George
lealyn-toledo
Jun 21, 2011 03:10 PM
95blazer1992
Mar 6, 2011 02:40 AM
pontiacmonstr
Sep 25, 2010 07:00 AM
davidh9732
Aug 28, 2010 12:57 AM
s10blaze
Nov 4, 2008 05:17 PM
