91 s10 blazer
Old Feb 17, 2019 | 04:54 PM
xPikez's Avatar
xPikez is on a distinguished road
Default 91 s10 blazer
I have a 91 s10 blazer 4x4 210k miles and ever since i had it for about 4 yrs ive always had a problem with the spark plugs always going bad and getting dirty within a month... Sometimes there is oil on the spark plug threads. Also it eats oil like crazy. I know that there was maintenance on one of the piston cylinders i think a sleeve was placed in it for compression loss or something. Other issues i have with it are just cosmetics. I would appreciate any feedback
Old Feb 19, 2019 | 05:15 PM
rriddle3's Avatar
With that amount of miles on the engine and the symptoms you describe, I would suspect worn piston rings and/or cylinder wear. Starting with a compression test you can begin to eliminate possibilities and home in one what is the true cause.
Old Feb 19, 2019 | 05:30 PM
xPikez's Avatar
thanks for the reply. A couple of other people i talked to suggested that would be it... I will do a compression toest for sure.
Tynan Tha Real Dill
Jun 1, 2017 07:37 AM
Uniquemel0dy
Jan 4, 2014 01:49 AM
medea1993
Jun 7, 2012 12:29 PM
bigdaddykane93
Jan 23, 2010 02:10 PM
afrench690
Apr 21, 2008 02:27 PM
