91 suburban fuel pressure problems help
Old Aug 22, 2010 | 11:08 PM
cardude59's Avatar
cardude59 is on a distinguished road
Unhappy 91 suburban fuel pressure problems help
I have a 91 suburban and I am getting what feels like a miss under load. I have done all the tune up parts and it still has this missing problem. I have tested the fuel pressure and it has 11 psi ( spec is 9-13psi) when the key is turned on. It then drops to 2psi when the key is turned off. When driving and I accellerate the pressure does not increase. At w.o.t it will drop about 1-2 psi. I blocked off the return line and the pressure went to 16psi and did not drop off. Here is the question. Does the fuel pressure need to increase when accellerating? Should the system hold the pressure when shut off? . I think I need to rebuild the FPR. My friend thinks that is not going to correct the problem. Please help us settle this.. Thanks for your help.
5.7l tbi auto trans 3/4 ton 4x4 no cel no codes
InsanePyro
Mar 11, 2012 02:35 PM
Roudy4x4
Performance & Brainstorming
Feb 23, 2009 07:56 AM
mustang2
Mar 28, 2008 10:05 PM
EuroGoldLS
Detailing
Jun 5, 2007 01:07 AM
Garrett
Dec 28, 2006 04:14 AM
