'92 Blazer 4.3 floods and wont start.
Old Jan 12, 2011 | 02:09 PM
chevyguy4lyfe's Avatar
chevyguy4lyfe is on a distinguished road
Default '92 Blazer 4.3 floods and wont start.
I just got a '92 blazer and it will not start. Pulled plugs and they are soaked with fuel. Its also getting spark but will not start. I removed the intake plenum and do not see any leaks. Pulled the poppet valves out and they seem to be functioning properly. Any help would be greatly appreciated.
Old Jan 12, 2011 | 04:52 PM
billbobagns's Avatar
billbobagns is on a distinguished road
disconnect fuel pump fuse and relay. Get a can of starter fluid. Crank, with no fuel pump for a min or two. No matter how flooded it is, it should dry out with no fuel pump. A shot or two from the starter fluid might help.
Once you get it dry, it will start and run with B12 or Starter fluid, but do this only for a few seconds to make sure it's no longer flooded.
Next, hook fuel pump back up and try again.
Note; Anytime you are working with fuel, keep an appropriate fire extinguisher handy and be alert of fire danger!
BTW, are you sure it's a 92? I thought they were TBI.
Old Jan 12, 2011 | 05:08 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
'92 was the first year for the CPI option.
Old Jan 13, 2011 | 10:49 AM
The thing about it is even if i let it sit and dry out as soon as i crank it over, about 10 seconds, it floods out again. I didn't see any clean spots or any other signs of leaks other than just a little bit of fuel in the bottom of the intake.
Old Jan 13, 2011 | 03:29 PM
While i was out in the garage i looked again and there is a clean spot right under the "nut kit" where it looks like fuel was leaking but cant find a leak. I can tell the previous owner had the intake off so they may have fixed the leak? I would upload pics but am not sure how to.
Old Jan 13, 2011 | 03:31 PM
Have you checked for spark at the plugs?
Old Jan 13, 2011 | 05:09 PM
Yup, its getting good spark. It just floods as soon as i crank it over. This ones really stumping me.
Old Jan 13, 2011 | 08:19 PM
JustJerry's Avatar
JustJerry is on a distinguished road
My 92 S10 with the W engine got so that it would flood. I could hold the accelerator pedal to the floor and it would start.
Leaking nut kit fixed that problem.
I might add, when engine was cold it would start OK, but after driving to Walmart which is about a 10 mile drive and parking it for about 15 to 30 minutes, when starting it would flood.
Old Jan 14, 2011 | 05:52 AM
nothing in the intake seems to be leaking but there is a clean spot under the nut kit. i am going to go back out today and try and track down a leak somewhere.
Old Jan 14, 2011 | 02:48 PM
Well i still couldnt find any leaks today, i put the intake back together. It still floods but now if i hold the pedal down it kind of pops like it wants to fire up but still wont fire. I removed the intake afterwards and there is no fuel in the intake. Going away for the weekend, hopefully when i get back someone will have something for me so i can have a vehicle again.
