94 4.3l running fast and getting hot quick
Old Jul 10, 2009 | 12:28 PM
Machman1182's Avatar
Machman1182 is on a distinguished road
Default 94 4.3l running fast and getting hot quick
hello i just put a 94 gmc 4.3 vortec into my 93 blazer. the vin letter is "w". the engine heats up quick, rear of engine gets hot faster. the rpms creep up when given full throttle. cant advance the timing past 10* ATDC w/o the engine racing up past 4,000rpm. timing marks are correct, and timing chain is good. vaccum is at between 3-4, found no leaks around intake. compression reads as follows: 1-145, 2-142, 3-134, 4-142, 5-140, 6-150. also brand new heads were installed before i recieved the engine. the question is why is is getting hot so quick? and why is there no pick up when throttle is applied?
Old Jul 10, 2009 | 07:35 PM
So it will not idle?... If so, have you verified that there are no vacuum leaks?
Compression looks good.
Old Jul 11, 2009 | 10:50 AM
it idles at 10* ATDC. and couldnt find vacuum leaks. sprayed soapy water and couldnt see any bubbles.
Old Jul 11, 2009 | 11:15 AM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
Propane works better than soapy water...
Old Jul 11, 2009 | 04:12 PM
Yeah, soapy water will not find vacuum leaks since the engine is sucking in air at a vacuum leak, not blowing it out.
dOgGiE_VoMiT
Sep 7, 2012 05:24 AM
Mandrwj
Apr 10, 2011 07:32 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
elementalnature
Aug 17, 2008 08:06 PM
blazinwoody
Engine & Internal
Jan 11, 2007 05:30 PM
