94 blazer with Vortec Motor
Old Aug 28, 2007 | 12:14 AM
compprat's Avatar
compprat is an unknown quantity at this point
Default 94 blazer with Vortec Motor
Need a guide on how to remove and install a starter. Im pretty sure its common sense, but I would just like to be sure. The starter is bad.
Thanks.
Old Aug 28, 2007 | 03:31 PM
Lil Blazer's Avatar
Lil Blazer is an unknown quantity at this point
Default RE: 94 blazer with Vortec Motor
lol i was going to post a topic on this cause i aslo need some help.
it is near the front passenger tire.
make sure positive batterey cable is unplugged
unscrew the wire the connects to the unit itself
unscrew the two bolts that hold it up. just look you will know which once.
now this is where i got confused
i cant figure out how to get the dam thing out of its place
i try lifting the side the is closest to front bumper then pulling the part that turns the gear out and then it gets stuck
bah
hope i helped you atleast a little
Old Aug 28, 2007 | 07:59 PM
green75's Avatar
green75 is an unknown quantity at this point
i have the same motor, you have to go thru the wheel well to getthe wires off be patient. i took a saws all and cut a lil of the alum bell housing about an 1/2 in to a inch then the starter will fall right down. or you can take the motor mount out and jack the motor up till the tit of the starter is cleared. its up to you . i used the saw cuz i didnt want to screw with the mount. made it alot easier
mrblonde108
Jul 17, 2017 07:52 PM
ussexplorer
Mar 31, 2014 09:00 PM
extreme
Dec 1, 2010 06:08 PM
debo42
Sep 14, 2009 06:34 AM
96blkblazer
Feb 26, 2009 04:29 PM
