95 4.3 vortec to 5.7 questions
Old Dec 11, 2012 | 12:45 AM
JT6850's Avatar
JT6850 is on a distinguished road
Exclamation 95 4.3 vortec to 5.7 questions
So starting a build of my own and have researched it up but still have some questions on a 4.3 to 5.7 swap. I know I need motor mounts and wiring harness a different computer and w.e else but as far as everything working correctly that is where i have questions, will all the gauges and everything work in the instrument panel. Will it effect my 4x4, will it work with 4x4. I want to do the swap and make sure I still have all my bells and whistles, remote starter and security system things like that. Please any input would be great, any pointers tips, do's and don'ts , cost too nobody has seemed to list how deep you gota go or how little you can get by on
Old Dec 11, 2012 | 05:42 AM
You have probably picked the most difficult year to answer this question and to perform this swap on because of how many different configurations, computer wise, that it came in. I am not sure of how many v8 vehicles came with the same screwed up system in 95, but if you can find a whole truck/car to scavenge harnesses from that would make your work easier. Sticking with a 95 GM donor will likely give the easiest results.
Once you find a truck/car that has the same computer setup, buy the factory service manual for both your truck & for the donor. Then sit down & start studying the wiring diagrams to determine where you need to graphed the harnesses together.
If your truck is an early 95 (OBD1), just dump in a modded TBI 350 and call it a day. If it is OBD1, you would only have to get the PROM flashed for the V8 tune after making everything fit under the hood and wiring up the motor.
I can't help you with your price as I think you are in for a real adventure. Price often depends on availability of parts and how much of the work you are doing yourself.
Old Dec 11, 2012 | 11:38 AM
JT6850's Avatar
The work will be done by myself and figures I went and bought the messed up year. Im not 100% for sure but i believe it is the later model. I wish i knew someone personally who has done a similar swap so I could ask them. The only thing im worried about is the computer stuff, if the vehicle was older there wouldn't be an issue, but u suggest finding a 350 the same model year, and transmission wise im pretty sure it will bolt up but will it hold up to the added power?
Old Dec 11, 2012 | 04:14 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
I can only help by saying that I have seen pictures of it being done.What your trying to accomplish is something I made the mistake of trying to do,which was put a 95 cpi in place of 96 sfi.Wiring harness nightmare.I switched my engine back over to 96 sfi.
mrblonde108
Jul 17, 2017 07:52 PM
fjallasport-ram
Feb 23, 2011 08:30 AM
extreme
Dec 1, 2010 06:08 PM
debo42
Sep 14, 2009 06:34 AM
96blkblazer
Feb 26, 2009 04:29 PM
