95 and 97 transmission interchangable?
Old Nov 29, 2009 | 06:05 PM
moldeck's Avatar
moldeck is on a distinguished road
Default 95 and 97 transmission interchangable?
I have a 97 blazer 4wd. looking at a 95 transmission 4wd both have 4L60E marked on the side. just want to make sure they are the same and interchangable
Old Nov 29, 2009 | 07:16 PM
Check to see if both transmissions state PWM on the pump cover (behind the torque converter on the front of the transmission). If not, no dice!
Besides, for the 96+, it is always safer to go up in years as more improvements were made along the way.
Old Nov 29, 2009 | 07:27 PM
hubert hefner's Avatar
hubert hefner is on a distinguished road
more than likely it does interchange. 96 and 99 have the same cause i put a trans out of a 99 in my 96 jimmy
Old Nov 29, 2009 | 08:04 PM
The change to the PWM TCC solenoid occurred sometime in '95. The a PWM transmission cannot be used in place of a non-PWM transmission and vise versa. So it comes down to whether or not this particular 95 has a PWM transmission.
You could also compare the valve body solenoids. The non-PWM valve body will not have the TCC apply feel solenoid. Your valve body needs to have all of the following components, specifically balloon 396:
There should be two solenoids on the front of the valve body that look the same (394 and 396 are the same PN).
Would you rather assume or check and make sure that the transmission is going to work??
Old Nov 29, 2009 | 11:54 PM
CHASER33's Avatar
CHASER33 is on a distinguished road
I have the same situation. I had a podunk mechanic tell me that the transmission from my 95 is capable of taking a chip therefor it cant be placed in my 97, could there be any truth to this? He claims he found this out by comparing VINS. How do I tell for sure if they are interchangeable?
Old Nov 30, 2009 | 08:41 AM
Read my posts above.
Old Dec 1, 2009 | 11:38 AM
moldeck's Avatar
got lucky!! I left to go buy this trans before anyone replied... both are PWM on the pump... Picked up the trans and transfer case for 150.00 Came with all the electrical wires front drive shaft... motor was allready pulled in the blazer it came out of. Drove over an hour one way to get it. so if it was wrong i was bumming
Swart, would you use the trans and case that was bought or put the transter case that was in back in. The only issue I had with the old one was the front wheels not locking in. I have searched your posts and think I have a spring problem. I also have a very holey vacume line comming from the trans too.
Old Dec 1, 2009 | 01:22 PM
Good deal!
If the transfer cases are the same model, use which ever one looks best to you. Since you know that yours works, maybe keep the other one for future use..?
Old Dec 2, 2009 | 12:25 PM
moldeck's Avatar
found a metal plate on the trans GM Reconditioned!! looking better and better.
Old Dec 2, 2009 | 03:37 PM
Hopefully that includes some of the improvements made along the way. Good find!
