95 blazer 4.3 vortecv6 sputtering
Old Mar 20, 2010 | 10:35 AM
azcardinals80's Avatar
azcardinals80 is on a distinguished road
Default 95 blazer 4.3 vortecv6 sputtering
ok i have a 95 blazer everytime i start the engine it sputters erratically and shut itself off the day before i had it at midas cause of a misfire in cyl. 4 they corrected it by put a new i dk what its called but its a round piece with teeth on it on the disturbator when i got the blazer back it started sputtering and shuting off on me after i leave it sit its starts fine wen i rev it it sputters and stalls out i have no clue whats wrong im thinkin maybe its sumthin w the cap and rotor can anyone help me plz
Old Mar 20, 2010 | 11:42 AM
TommySkillz's Avatar
TommySkillz is on a distinguished road
Um do a fuel pressure test, check the coil and the module, other than that Dunno?
Old Mar 20, 2010 | 12:16 PM
will do im doin the cap and rotor tommorow maybe thats it if not ill do the module then the coil
Old Mar 25, 2010 | 02:02 PM
juddkennedy's Avatar
juddkennedy is on a distinguished road
azcardinals80 did it work? Did you install a cap and rotor?
Old Mar 25, 2010 | 05:56 PM
JIM MACGILLIVRAY's Avatar
JIM MACGILLIVRAY is on a distinguished road
Azcardinals80 sounds like you have idle air control valve acting up maybe ? Or trottle bore control,get to a junkyard and obtain the parts or buy em new, i had same problem and it was trottle related ,changed the parts near trottle intake and engine smootened out instantly,good luck ,jim
nokkturnal
Mar 14, 2011 06:48 PM
mritech
Nov 29, 2010 08:05 PM
Gold3n Monk3y
Apr 14, 2010 05:34 PM
dwaple303
Jan 27, 2009 03:30 PM
scott96
May 1, 2008 11:47 PM
