95 blazer with flashing check engine light
Old Jun 4, 2011 | 10:15 AM
dtp12's Avatar
dtp12 is on a distinguished road
Default 95 blazer with flashing check engine light
I am new to this forum, and i orginally posted this in the new mwmber forum, and didn't think is was in the correct location. i am sorry if this got posted twice.
i have a 95 blazer, according to the VIN, it is a 4.3L v6 with CPI. the check engine light was on with a code of 1406. it was running fine until the light came on. i replaced the EGR valve. i reset the the system and i no longer have any codes. now when i drive the check engine light flashes and the engine runs very bad. i have changed the plugs, PCV valve, air filter. after driving for about 10 - 15 min, the light stops flashing, but it still runs very rough. my research says the flashing check engine light means misfire, but with out any codes how do i know what is causing the problem. i wasn't having any problems before the 1406 trouble code.
any help would be greatly appreciated.
thanks
Old Jun 4, 2011 | 06:52 PM
Z71_Guy's Avatar
Z71_Guy is on a distinguished road
flashing SES light does mean it has a massive miss fire, it should throw a code though. double check all the vacuum line and anything that may have broken while replacing the EGR
cory30189
Sep 28, 2012 09:23 PM
Mitchman38501
Jun 16, 2011 01:00 PM
65Cents
Aug 19, 2010 08:52 PM
zombiewoof
Feb 1, 2009 12:06 PM
