95 Blazer keeps shutting off. No service engine light
Old Aug 2, 2020 | 05:40 PM
branes01's Avatar
branes01 is on a distinguished road
Default 95 Blazer keeps shutting off. No service engine light
Here we go. Bought a 1995 blazer 2 door last weekend. On the drive home it sputtered and shut of going up a hill. After a few seconds it started right back up and was able to get it home. Two days later was driving with wife and the thing shut off again. Going up a hill. Took it to a shop and they returned it. Said nothing was wrong. So i started it up and let it idle for a while. Well it flashed the service engine light for about 10 seconds. Come to find out that its the Camshaft position sensor. Replaced it. Driving down the
road today and it shuts off AGAIN! What on earth is goin on? It runs great for about 10 minutes and then it just shuts down. When i go to restart itll start and then bog down again. If i let it sit for about 10 minutes it starts right up and runs fine. Please help!!
Old Aug 2, 2020 | 05:46 PM
go chevy's Avatar
Just a quick thought, but maybe the fuel filter and or fuel pump??? I am sure others with more experience will be on here 2 help you out...
Old Aug 5, 2020 | 07:14 AM
Stro53's Avatar
Stro53 is on a distinguished road
it could be many things but to me it is starving for fuel..Try a new filter fuel and if that doesn't work could be the pump.When you idle can you hear the fuel pump like wining?If you don't it may be the pump.
Old Aug 5, 2020 | 04:58 PM
branes01's Avatar
So i still am afraid to drive. Sitti g here letting it idle i still notice a miss and the fuel gauge is moving back and forth about an eighth of a tank. HELP!!!
Old Aug 5, 2020 | 05:55 PM
Have you looked into either of what the previous post say?
Old Aug 5, 2020 | 09:06 PM
Stro53's Avatar
Default Mine Doesn't Shutdown
Mine when first started and even WHen hot doesn't wanna go WHWN I gas it..And then kicks in..If I just punch it nothing then kicks in..Kinda same issue.but different..
Old Aug 5, 2020 | 09:09 PM
Stro53's Avatar
Mine hesitates when first started and you can gas it no power.Seema to not be getting any fuel.Thpught of starting with.fuel filter but maybe the pump..I dint hear the pump humming or.nothing.What can it.be.
Dustin Grant
Nov 22, 2015 03:59 PM
learjets
Apr 4, 2010 06:10 PM
captrim99@yahoo.com
Dec 10, 2008 07:30 PM
thogbert
Nov 6, 2008 06:25 PM
elementalnature
Mar 30, 2008 01:54 PM
