95 blazer in limp home mode
Old Mar 10, 2010 | 03:11 PM
dready1084's Avatar
dready1084 is on a distinguished road
Default 95 blazer in limp home mode
Tranny won't go into first or overdrive shifts hard between 2nd and drive. Will work once in a while
Old Mar 11, 2010 | 02:35 PM
1997 red blazer's Avatar
1997 red blazer is on a distinguished road
Ok, what is the Question you have for the Forum ? It is a 95 blazer right ? 4wd or 2wd ? How long has it been doing this ? How many miles on the blazers trannie ? Give us a little more Info PLEASE ?
Old Mar 11, 2010 | 03:53 PM
dready1084's Avatar
It is a 2wd. 138000 on blazer for 6 months it has been saying up . It worked for about a month in January and then acted up again. Have recently changed tranny filter did not fix
Old Mar 11, 2010 | 03:54 PM
dready1084's Avatar
Why is my tranny not allowing me to use first gear or go into overdrive
Old Mar 11, 2010 | 04:16 PM
So the Replacement trans has how many mile on it ? Not the Blazer. For six months what ? Not sure what you are trying to tell us ?
Old Mar 11, 2010 | 04:42 PM
dready1084's Avatar
For six months the tranny has not been able to go into first gear it starts out In second no matter where the shifter is located and it won't go into overdrive. Just uses second and drive. Is original tranny I believe have not put new one in. My abs light just started to come on today as well don't know if it has anything to do with it
Old Mar 11, 2010 | 06:07 PM
Abs is another problem.
Old Mar 11, 2010 | 07:27 PM
kevin turner's Avatar
kevin turner is on a distinguished road
I belive there is a little box on the side of the tranny it controls the shifting and play with the linkage ajust it up and down then try to see if it will go into frist. I had this prob. on other rides. Ive never really look at the tranny on my blazer. But it should be about the same. When they put the tranny in they might have not done the proper ajustments you will need. Hope this helps ya.
Old Mar 12, 2010 | 10:10 AM
dready1084's Avatar
The tranny never was dropped it happend while I was driving it
rviolette84
Mar 8, 2013 12:25 PM
BlazerBoyz1
Jan 13, 2011 12:45 PM
Migra311
Sep 19, 2010 10:20 PM
Pobey
Aug 5, 2010 05:21 PM
mrblonde108
Feb 4, 2010 11:36 PM
