95 blazer manually switch to 2WH (stuck in 4WLow)
Old Dec 9, 2014 | 12:14 PM
MountainMermaid's Avatar
MountainMermaid is on a distinguished road
Default 95 blazer manually switch to 2WH (stuck in 4WLow)
The transmission is bad. I need to get it to a shop to have it rebuilt, which will be approximately 40 to 50 miles away. It will drive forward (won't go into R or into N, so it can't be pulled backwards). The problem is, it is stuck in 4-wheel low and won't go into 2-wheel high. It is too far to drive in low, and If I put it on a trailer, I can't get it off without disconnecting the drive train again. Is there a way to manually get it out of 4-wheel low? Please help! Thank you!
hpblazer
Mar 22, 2013 12:12 PM
jdwjohn
Jun 1, 2011 09:04 PM
hill1
Jun 5, 2010 01:40 AM
joe72
Aug 5, 2009 04:30 PM
98BlazerLS
Jan 6, 2005 10:37 PM
