95 blazer starting problem
so the last couple weeks my truck has been acting up. it takes a handful of times to get it to turn over if it even wants to turn over. battery sits at 12 volts non running at 14 volts running. battery is good, so it may seem. most recently the only way to get the truck running is to jump it. i did forget to mention that i did charge it for a good 24 hours. it started perfect for a good 2-3 days then went back to the same problem. i dont think its the alt because i have a high output alt for my sounds and it seem to charge the battery perfectly fine ( have all been taken out due to this problem). the problem is persistent which kinda sucks. anyone gots some ideas? i dont feel like spending a isht load more money on this thing.
I'm thinking it might be your starter have you had it tested?
no i havent done anything with the starter yet. thatll be tom when its not raining. ive had a few people tell me it could be that then i had a few tell me theres no way it would be that.
cgrett
11-15-2010 09:08 PM
Sprocket
03-20-2008 09:39 PM
lukewb
14
12-02-2006 02:23 AM
