2000 Blazer Fuel Filter
Old Aug 24, 2009 | 04:02 PM
matthew.chapman1's Avatar
matthew.chapman1 is on a distinguished road
Default 2000 Blazer Fuel Filter
Just recently bought my 2000 Blazer. I am planning on buying a new fuel filter, but haven't even tried looking for it yet so i figured i would just ask some people on here.
Also is this something fairly easy to change?
Old Aug 24, 2009 | 04:57 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
The filter is located in the frame on the drivers side kinda behind the drivers seat area, and its easy to change with the correct tools.......
Old Aug 24, 2009 | 06:11 PM
AJBert's Avatar
You can pick up a new filter at any auto parts store.
Old Aug 24, 2009 | 10:48 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
Depening on where you live and how often its been changed you probably are gonna want to soak the nut with some good penetrating oil. I had to wrap a rag soaked in it for a few days before mine would come loose,also depending on the filter they can be a bear to slide back in the bracket,the fram I put on seemed like it was just a hair too large.
Old Aug 25, 2009 | 12:19 AM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
i would get a AC Delco filter and put that in. also put some white grease on the threads of the fittings so it will come apart easy in the future. on mine i also left out the plastic bracket that it slides into...
Old Aug 31, 2009 | 02:45 PM
aaron.b's Avatar
aaron.b is on a distinguished road
You're better off leaving the old one in than putting a Fram in there.
Old May 18, 2010 | 02:13 PM
deaconx's Avatar
deaconx is on a distinguished road
Thanks for the info. Is there anything that should be done to relieve the pressure before taking the filter off? I plan on changing mine.
Nevermind, I found this thread https://blazerforum.com/forum/showth...ng+fuel+filter
Last edited by swartlkk; May 18, 2010 at 04:21 PM. Reason: **Combining Consective Posts** - Please use the EDIT feature to add information to your post if another member has yet to reply.
Old May 18, 2010 | 02:17 PM
2002XTREME's Avatar
If you do the filter after the truck has been turned off for awhile, most of the pressure in the system will have subsided.. When i changed mine, I let no pressure out of the system first and havent had any problems yet and that was 2 years ago..
Old Jun 15, 2010 | 06:20 PM
83Blazer4x4's Avatar
83Blazer4x4 is on a distinguished road
Not trying to resurrect an old post here but my understanding of fuel filter maintenance was every 6 months, even if I am wrong it is just peace of mind considering the cost and all.
aerovette99
46
Sep 28, 2015 10:04 AM
taylort232
Sep 20, 2011 08:43 AM
95jblaze
Aug 27, 2011 03:46 PM
riverjamie
Sep 24, 2007 08:21 PM
AutomagicLS1
Apr 13, 2007 12:54 AM
