95' Blazer V6, Odd fuel problem.
Old Aug 27, 2013 | 03:35 PM
T.C.'s Avatar
T.C. is on a distinguished road
Question 95' Blazer V6, Odd fuel problem.
Hello,
I've done several searches trying to get some answers before I go spending more money on new parts. Last week my truck simply cut out while coming off the interstate. I was unable to refire, had to tow it home. I assumed from the way it died it was fuel related, and since the previous week leading up to this during the heavy rains we've had here I've been having a dead cylinder and a misfire condition.
I replaced the fuel pump and filter about a year ago, so my first inclination was a dead spider injector. Since to get to the injector you have to take the plenum off, I'm also performing a full tune up.
That being said, I noticed when turning the ignition on the fuel pump is now making a really deep groaning sound, not the sound it normally would make. So I pulled the fuel filter, then turned the ignition to run, the pump whines, but no fuel comes out of the line.
Drained the fuel filter and a fair amount of dirt came out with the gas. Not sure where to go from here..
Thanks for any advice in advance,
TC
Old Aug 27, 2013 | 05:39 PM
If the pump runs but doesn't squirt fuel, there's a problem with the pump. Could be excessive dirt in the tank clogged the filter at the pump, or it could be a bad pump.
Old Aug 27, 2013 | 09:44 PM
T.C.'s Avatar
That was what I was leaning towards, just wanted to get a second opinion before a buy another new one. Any tips on cleaning the tank out? I'd rather avoid buying a new one..
Old Aug 28, 2013 | 05:26 PM
If you remove the fuel pump module, you should be able to see if there's dirt in the tank. If no dirt, the pump has a problem. What brand pump did you install?
Old Aug 30, 2013 | 10:57 PM
T.C.'s Avatar
Airtex.
But this time I'm putting in an ACDelco fuel pump. I was told ACDelco is a recommended brand for blazers.
Old Aug 31, 2013 | 06:30 PM
Airtex pumps are fine, but not in a GM if you want it to run properly. Keep us posted.
bigbeast
Aug 18, 2010 10:30 PM
V8 BUG
Feb 11, 2010 12:06 PM
blbikerood
Jan 30, 2010 12:13 PM
Mudd8227
Nov 19, 2009 08:32 AM
Heffty
Engine & Internal
Mar 12, 2007 04:12 PM
