95 Blazer won't shift past second
Old Feb 2, 2011 | 12:59 AM
sbleier's Avatar
sbleier is on a distinguished road
Default 95 Blazer won't shift past second
My daughters car developed a shifting issue. When you put it in OD, it goes from 1st to 2nd and then appears to go into neutral before going back to 2nd.
I can manually shift it into 1st or 2nd but when I put it in D, it acts like Neutral.
I noticed a vacuum line cut under the transfer case. Repaired it - no change.
I disconnected the battery to get at the vacuum line - not sure if that had any influence. I hate to replace the tranny if it is something else less expensive. Fluid level was a little low. Added a half pint. I think it looked clean but need to re-check. Prior to this, it shifted OK, but you had to let it warm up for a minute before it would shift OK.
Old Feb 2, 2011 | 07:23 AM
*Moving to Engine & Transmission* - Technical questions belong in the appropriate technical section. Please read the descriptions of the sections and choose the one that best describes the nature of your question.
Old Feb 2, 2011 | 08:51 PM
TZFBird's Avatar
TZFBird is on a distinguished road
Check the fluid condition. I'm betting a rebuild is in the near future. How many miles on vehicle?
Old Feb 3, 2011 | 10:12 AM
sbleier's Avatar
Default Blazer w/shift issues
The vehicle has 133K, which I would think is low for tranny issues.
chcknugget
Nov 26, 2013 03:24 PM
texas4x4blaze
Jul 16, 2010 08:51 PM
2KBVDA
Oct 30, 2008 03:52 PM
dimone545
Sep 3, 2008 08:25 AM
96Ls4Dr
Feb 6, 2007 05:28 PM
