'95 Jimmy 4x4 Bad Acceleration
Old Jul 11, 2017 | 12:40 PM
Tynan Tha Real Dill's Avatar
Tynan Tha Real Dill is on a distinguished road
Originally Posted by newguy
scrolll down several sections and theres a pic of a fix you can do. They are called comression couplers/fittings
Ok I can't find that pic to fix the twisted fuel line. And on those loosen exhaust pics you seen, what are those parts called, how big are the bolts, and do they have gaskets?
Old Jul 11, 2017 | 12:45 PM
newguy's Avatar
sorry didnt add the link , they`re called flanges and I think thers gaskets. The auto parts store sohuld be able to help with and the bolt size heres the link https://blazerforum.com/forum/2nd-ge...-filter-91472/
Old Jul 11, 2017 | 05:26 PM
Ok I bought a straight pipe to temporarily replace the cat converter. The measuring tape pics are the measurements of the gap from the missing cat. The pipe I bought is 18" long and the holes are 2 1/2". The gap under my truck where the cat used to be is 14 1/2 and the pipe hole is 2 1/2. Is the pipe I bought too long? And should I have gotten a size smaller hole to slide it in easily? Also I bought bolt clamps to clamp it down.
Attached Thumbnails '95 Jimmy 4x4 Bad Acceleration-20170711_152951.jpg   '95 Jimmy 4x4 Bad Acceleration-20170710_153137.jpg   '95 Jimmy 4x4 Bad Acceleration-20170710_153022.jpg
Old Jul 11, 2017 | 05:47 PM
newguy's Avatar
cut the pipe with a hacksaw. you will need to buy adapters
to connnect them
Old Jul 11, 2017 | 05:50 PM
to connnect them
I need to cut the pipe? Is it too long? What about the holes is that enough to slide it in my exhaust pipes? And what adapters? The bolt down clamps won't work?
Old Jul 11, 2017 | 05:55 PM
newguy's Avatar
if the new pipe slides over the old you should be good. length and everything. if they are the exact same size you will need adapters
Old Jul 11, 2017 | 06:01 PM
newguy's Avatar
Old Jul 12, 2017 | 10:47 AM
What are the bolts to the flange that connect the exhaust pipe and exhaust manifold? Couldn't I just pull 6 good ones from a newer car or truck at a salvage yard?
Old Jul 12, 2017 | 10:52 AM
newguy's Avatar
I would get new ones from an auto parts store or hardware store
Old Jul 12, 2017 | 10:55 AM
Do they have to be those exact bolts with the springs or just a bolt and nut ?
