'95 Jimmy 4x4 Bad Acceleration
Ok will do. Truck drives alot better.. Now I have a shifting problem...after I drove it, I went to put it in Park, with the handle all the way up but stays in drive. Assuming it's in park, I try to fire it up and it doesn't turn over. So I have to manually shift it into neutral, it doesn't go into park... Shifts fine driving though
Please replace the line with original metal. As Newguy points out, that P/S hose is not designed for fuel and using those clamps is definitely not a good idea. If the hose blows off the line you could end up in a big fire and we don't want that. 60+ psi is a lot of pressure. final thing... I see what appears to be a cut or split in that hose, just to the top right of the upper hose clamp.
Ok I'll fix it, but I seriously lack the funds right now due to being unemployed for the last 6 months, I'm literally pulling money from the sky to accomplish what I've already done. I have no choice but to keep an eye on it and pray on it. Without work there's no money, without money there's no parts, without parts there's no fixing it. I have no resources for help financially, so the chances I'm taking, is a must or I'm stuck !! Help with a fuel line kit that actually fits my fuel lines would be very helpful ! Then I can wait for more money to fall out of the sky to buy it. I appreciate you guys concerns, but I'm telling y'all the situation at hand here. I have to or I'm up **** Creek without a paddle...
This is a proper repair. $20 max repair.
Attachment 35009
Attachment 35009
