'95 Jimmy Transmission Crossmember
Old Sep 23, 2017 | 03:51 PM
Tynan Tha Real Dill's Avatar
Tynan Tha Real Dill is on a distinguished road
Default '95 Jimmy Transmission Crossmember
What is the size of the nuts or bolts that hold the cross member to the frame ? Need to pull the cross member and jack the back of the transmission up to drop the pan to replace the filter.
Old Sep 23, 2017 | 09:49 PM
slimshady's Avatar
slimshady is on a distinguished road
If they are the OEM bolts the bolt heads are 13mm and the nuts are 15mm. The trans mount nuts are 15mm. If they have been replaced they could be anything.
TheBrandit
Sep 29, 2012 09:52 PM
lynnmcd
Suspension Tech
Apr 3, 2008 08:47 AM
mdemers2006
Jul 26, 2007 06:41 AM
mars004
Dec 13, 2006 02:04 AM
