95 Jimmy transmission started leaking??
Old Jul 5, 2013 | 01:16 PM
griz763's Avatar
griz763 is on a distinguished road
Default 95 Jimmy transmission started leaking??
Afternoon guys I have a 95 Jimmy and while driving home the other night it started smoking like mad then stopped then came back but not as much was very close to home thank goodness parked it and found fluid all underneath truck. It looks as if it may be the pan gasket has gone bad but its hard to tell. I replaced the gasket and filter about 3-4 years ago so I am planning to jack up and move forward with the thought as its a bad gasket do any of you guys have any other things that I should check or do before dropping pan? Before it started smoking it was driving/shifting fine and after letting it set and then later I pulled into my barn it would shift perfect into gear but you could tell it was definatly low on fluid I pulled into barn. Any thoughts and or help would be greatful.
Old Jul 5, 2013 | 01:30 PM
chris015's Avatar
first off,spray everything down with some degreaser. Then wash it all off with a good spray nozzle on a hosepipe. let it dry,NOW you can see where its leaking. it'll either be the pan,tailshaft seal,or front seal. Just hope its not the front seal.
Old Jul 5, 2013 | 01:39 PM
griz763's Avatar
That was my plan gor tonight what do I look for on a front or rear seal leak
Old Jul 5, 2013 | 01:42 PM
chris015's Avatar
Well,you look for leaks lol. If its the rear seal,itll be the seal where the driveshaft slides into the transmission. If its the pan,well ofcourse the pan will be wet. If its the front,itll run down and out of a lil hole of the bellhousing cover.
If its the pan,try tightening the bolts down a little on the side its leaking. Dont torque em down,or extremely tight.
Old Jul 5, 2013 | 04:10 PM
griz763's Avatar
Lol thanks wasnt sure what to look for on a front seal leak
Old Jul 16, 2013 | 05:40 AM
griz763's Avatar
Thanks for the input it ended up being the rubber gromet and the bolt on the trans fill tube bolt had fallen out at sometime and rubber was hard as a rock all back together
737mechanic
Sep 4, 2014 05:23 PM
scottyk
Feb 27, 2007 11:51 PM
oshkosh
Jan 27, 2007 01:22 PM
88s10Blazer
Jul 24, 2006 02:11 PM
chevychic4life
Engine & Internal
Apr 10, 2006 12:22 PM
