95 Transmission (Need Pictures)
Old Mar 29, 2010 | 07:54 AM
speedfreakz's Avatar
speedfreakz is on a distinguished road
Default 95 Transmission (Need Pictures)
Apparently they put to different styles in my blazer. 1 and 2 piece trannys. Can you gentle man post some pictures of what your transmissions look like? Thanks in advance
Old Mar 29, 2010 | 12:49 PM
They are quite unmistakable. There are pictures of the two different cases available on the internet.
If you have the two piece case, your bell housing will be a full circle bell housing and there will not be the earlier large sheet metal dust cover.
Old Mar 30, 2010 | 05:49 AM
Default ??
either one will work in my blazer correct?
Old Mar 30, 2010 | 07:49 AM
Should, yes. '95 was the transition year to the PWM TCC control. You need to make sure that your current transmission pump (in front of the transmission behind the torque converter) has PWM embossed on the front of it. If it does, you are good to go.
xgiovannix12
Aug 4, 2011 10:39 PM
93LT
45
Nov 13, 2010 06:13 PM
ivannj
Jan 30, 2006 02:36 PM
swartlkk
13
Oct 3, 2005 11:10 PM
the_mind
Aug 30, 2005 11:53 PM
