96 blazer 4x4 semi enguaged
Old 04-16-2012, 09:49 PM
aa21830's Avatar
aa21830 is on a distinguished road
If you've removed vacuum from the system and there's no other problems with the 4WD system, then the 4x4 should be completely disengaged. You can still enegage the transfer case, but the front hubs will not be locked, so you should have no 4x4.
If you've removed vacuum and 4x4 is still partially engaged, then you've got problems in the front differential.
Old 04-16-2012, 10:00 PM
alprix's Avatar
alprix is on a distinguished road
i hope that your understanding what i am saying. ok so youre saying once i remove the vacuum hose off the t case switch it will unlock the 4x4 an go into 2wd right i just want to make sure cuz this truck have to be driven so my girl can goto work an i dnt have to keep taking off from my job if you wanna msg me on msn so i could better understand this 4x4 crap my msn name or addy is dsmridin@hotmail.com
Old 04-17-2012, 06:15 AM
Holy run on sentence... Please use proper spelling, punctuation, and grammar. You might just see the responses come a little more frequently if you show that you actually care about making your posts easy to read for others.
Besides, there is TONS of information available to you about 4wd problems if you would just search for it. HINT --> There is a thread specifically about this in the Tech Article DIY section, an index of which can be found in my signature below. That section should be the first stop for people that are having problems as it is a quick read through to see if there are already articles on your particular problem.
Old 04-18-2012, 07:24 PM
alprix's Avatar
ok so i put my truck up on ramps an i didnt feel or see the t/c switch. so what i did see was like a plug plugged into a thing that looked like the t/c switch it was like under the axel metal sleeve an there was or looked like a vacuum hose on it. remind you that this is a 96 an i also have a little quick video i took an here is the link . people please respond quick my gf is really getting on my nerves about this damn truck
April 18, 2012 8:10 PM - YouTube
Old 04-19-2012, 11:04 AM
aa21830's Avatar
I believe you have found the electronic sensor which detects that the front differential cable has been pulled by the actuator. This is not the vacuum switch - that one sits on top of the transfer case, behind the transmission (directly under the back side of the driver's seat, more or less). It's a little tricky to find if you don't know what you're looking for, but look for 3 black hoses, all kind of tied together and joining into a rubber cap/connector thing. The hoses all connect to the transfer case vacuum switch, which threads into the top of the tranfer case.
Old 04-19-2012, 12:37 PM
alprix's Avatar
since im having such a hard time locating this thing can someone post a quick video please of where the t/c switch is cause im getting so frustrated.
Old 04-19-2012, 01:16 PM
chcknugget's Avatar
chcknugget is on a distinguished road
The transfer case is bolted to the back of the transmission and the front drive shaft runs from it to the front differential. The switch is right above where the front driveshaft pops into the transfer case. There are 3 black vacuum lines connected to a plug that plugs into the switch. If you can't find it you might be better off taking it to the shop.
Old 04-19-2012, 02:28 PM
aa21830's Avatar
Old 04-19-2012, 05:45 PM
alprix's Avatar
i hope so, thanks alot guys
r0k0
06-28-2012 06:29 PM
grantd
01-17-2010 03:30 PM
94_SBlazer
09-26-2009 02:43 PM
bdubs
12-26-2008 07:02 PM
Blazin1
10-21-2008 07:54 AM
Quick Reply: 96 blazer 4x4 semi enguaged
