96 Blazer encoder motor
Old Jan 15, 2011 | 07:24 AM
spille's Avatar
spille is on a distinguished road
Default 96 Blazer encoder motor
I talked to a mechanic and he says I need to replace the encoder motor in my blazer, does anyone out there have directions on how to replace the motor, do I need to remove the drive shaft? Need help please. Thank you
Old Jan 15, 2011 | 08:17 AM
old skool luvr's Avatar
look around the forum, it's all out there.
Old Jan 20, 2011 | 12:27 AM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
First remove the u-joint on front drive shaft, then pry the driveshaft off it will come easy when pryed but won't if you just try to pull it. Then remove 3 bolts on encoder motor then put on new encoder motor you will have to make sure it's in the right position to line it up. then reinstall bolts slide on driveshaft and reinstall u-joint. It's about a 30 min job.
LesMyer
38
Jan 9, 2020 11:45 AM
drs99blazer
Apr 5, 2014 07:39 PM
apross44
Sep 21, 2010 08:52 PM
OldBlazer
Jan 10, 2007 01:37 AM
dusted800
Nov 18, 2006 10:27 PM
