96 blazer hard/rough start
Old Dec 16, 2014 | 11:09 AM
Jdc3333's Avatar
Jdc3333 is on a distinguished road
Default 96 blazer hard/rough start
I have a 96 blazer 4x4 and sometimes it doesn't want to start and just turns over and when it does it idles at about 200 rpms and will die if you don't give it any gas but if you touch the pedal it goes to normal rpm and idles fine. I am not getting any codes from this. Any help is appreciated. Thank you
Old Dec 16, 2014 | 03:27 PM
Gregg64's Avatar
Gregg64 is on a distinguished road
Got to be a code hiding in there some where. That condition could throw any number of codes.
Old Dec 16, 2014 | 06:06 PM
Jdc3333's Avatar
I went and checked again and there was an evap malfunction and catalyst below threshold, so would it be the evap doing it ?
Old Dec 17, 2014 | 04:03 PM
Gregg64's Avatar
Yes it could, so could the catalyst issue. need to start looking for vacuum leaks also.
Old Dec 17, 2014 | 05:36 PM
Jdc3333's Avatar
What is the catalyst ?
Old Dec 18, 2014 | 06:39 PM
Gregg64's Avatar
Catalytic converter. You probably are showing a bad O2 sensor , that or the cat is bad.
Zach8846
Mar 11, 2014 10:43 AM
4.3vortec
Nov 26, 2013 04:02 PM
syriusly
Feb 23, 2013 07:04 AM
nitsudredle
May 1, 2012 01:18 PM
N3ROST4R
21
Feb 29, 2012 09:22 PM
