96 blazer hot start problem
Old Aug 5, 2008 | 01:24 PM
concpumper's Avatar
concpumper is an unknown quantity at this point
Default 96 blazer hot start problem
When the weather is hot and I have gotten the blazer at operating temps, I have a problem if I shut it off then after 3-4 minutes try to start it again. It catches for a second, then just cranks and cranks. If I wait another 10-15 minutes it startsnormally. It has been doing this for 3 months. ALWAYS starts after it has had a chance to cool down. I replaced the computer (had it flashed for my vin) and the engine temp sender by the thermostat. Ialso replaced the fuel pump relay in the glove box. It seems that the relay is getting constant voltage and works by using the ground as the switch (probably from the computer). Any ideas? Hot in Oklahoma!
Old Aug 5, 2008 | 07:58 PM
Hanr3's Avatar
Default RE: 96 blazer hot start problem
short answer ICM get it tested.
Old Aug 6, 2008 | 10:46 AM
concpumper's Avatar
had icm checked at local autozone and it passed. They did say that they might not be able to get it hot enough to fail. Any other ideas before I pay $71 on a guess?
Old Aug 6, 2008 | 03:54 PM
rriddle3's Avatar
How many cycles did they put it through? It usually takes ~10 to get it hot enough to cause failure (if it's going to).
Old Aug 7, 2008 | 11:05 AM
concpumper's Avatar
Replaced the ICM and still does the same thing. Rechecked the fuel pump relay (new) and it does get power and can hear it latch. Wait the 10-15 min and click boom start.
Old Aug 7, 2008 | 12:02 PM
raylo's Avatar
raylo is an unknown quantity at this point
To narrow things down you really need to check for spark and put a fuel pressure gage on it when you are having the problem.
Old Aug 7, 2008 | 04:36 PM
concpumper's Avatar
It is getting spark - will run on ether when it happens. What am I looking for on the fuel pump pressure and how to tell the diff between a week pump and faulty regulator?
Old Aug 7, 2008 | 06:41 PM
A faulty regulator will bleed off pressure after you turn the key off. A weak fuel pump won't bleed pressure when its off.
stevenhousden
Jul 6, 2014 05:56 PM
Mandrwj
Apr 10, 2011 07:32 PM
88_s10
Jan 15, 2011 05:04 PM
blazerJim1701
Jul 26, 2009 09:18 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
